How to get Sweet Home 3D working on Ubuntu 16.04 LTS?
This topic has been viewed 37158 times and has 22 replies
Re: How to get Sweet Home 3D working on Ubuntu 16.04 LTS?
geetee, thanks for your efforts, but before speaking about distribution in Ubuntu repository, it would be nice that Sweet Home 3D simply works. Please, can you confirm that the Beta 7 works under the various Linux systems at your disposal?
Thank you Puybaret!
The Beta 7 appears to be working on a machine with Linux Mint 18 64k Cinnamon, AMD Proc, ATI Radeon grafix card. Did a quick and dirty... downloaded the beta version extracted to the desktop and launched the executable. Performed a simple validation where I opened an older .sh3d file, edit, save, and reopen with no issues.
Never had a problem with sh3d until installing Mint 18 on this machine. Attempted sh3d installs with several different versions, always getting the same results others in here are experiencing. Tried different video drivers and, versions of java with no success... The struggle was real. Thanks again.
sunshine11
Hello all,
i could confirm that the long term issue with AMD graphic card seems to be fixed
(tested with Ubuntu 14.04 LTS and Radeon HD 4850)
The error reported here http://www.sweethome3d.com/support/foru ... hread,2236
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x6db6db41, pid=2728, tid=1838828352
# JRE version: 6.0_45-b06
# Java VM: Java HotSpot(TM) Server VM (20.45-b01 mixed mode linux-x86 )
# Problematic frame:
# C [libGL.so.1+0x40b41] __float128+0x3091
has disappered. Thank you Emmanuel for trying so hard to fix it.
