Plugins manager
This topic has been viewed 105396 times and has 50 replies
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
Re: Plugins manager
Post by dorin »
Thanks YGYL!
You've made a hard work to support this community.
I'm not joking wile, in the past, I've try to make translation and I knew what it's mean. It's not an easy task IF you want to do a good job.
I will add You's translations to all my new versions of my plugins.
Thanks!!!
Re: Plugins manager
Post by dorin »
@Daniels118
What if You update version including here?(now v 1.5)???
Daniels118
Country: Italy
Re: Plugins manager
Post by Daniels118 »
Hi, I'm happy to announce that the Plugin manager official repo now supports plugins within zip archives, so these plugins will show up in the Plugin manager without the need to update.
Re: Plugins manager
Post by Keet »
You should change the confirmation window that a plugin is updated to a always on top modal window. Currently if you updated a plugin and clicked next to the window the "plugin ready ..." window is hidden behind the manager window. Now it seems like the program hangs so you have to move the manager window to see the OK window.
Daniels118
Country: Italy
Re: Plugins manager
@Keet thank you for reporting this bug, I will include the fix in the next release.
geewee
Country: DE
Re: Plugins manager
Post by geewee »
Hi, I installed the program manager without errors, but cannot run it. Clicking on Toold/Plugins manager gives this error message:
"No enum constant it.ld.sh3dplugins.pluginmanager.UpdatesHandler.Tag.descriptor"
I installed PluginManager 1.0 from sourceforge since download from http://daniels118.altervista.org/sh3d/pluginmanager/ failed with message "connection failed".
Win 11 Home 22H2, Build 22621.2861
Sweet Home 3D 7.2
Java 3D 1.6.2a - JOGL 2.5.0
Re: Plugins manager
Post by Keet »
Ah, if I had known you installed Plugins Manager 1.0 I wouldn't have send you to this thread.
That is an old version of the Plugins Manager. Get the latest version here .
As on this forum on sourceforge posts go from first to last so the post with the last version is somewhere at the end, in this case on page 2. The link is for a direct download of version 1.5.2. That should work a lot better ;)
geewee
Country: DE
Re: Plugins manager
Post by geewee »
Tahnks, that one works now!
Daniels118
Country: Italy
Re: Plugins manager
Version 1.5.3
  1. Display cumulative changelog
  2. Fixed settings panel
  3. Fixed French translation
  4. Fixed last check time format[/list=a]Download from SourceForge or update from itself!
    Thanks to EncoNyito for bug reports!
Re: Plugins manager
Post by Keet »
@Daniele
You might want to check the "Replace furniture" plugin in the plugin list since it doesn't seem to work anymore and blocks Sweet Home 3D from starting beyond the splash screen. At least my 7.2. on Linux doesn't work with it.
Maybe remove it from the list if it also doesn't work on other systems so other users will not run into the same problem.
