Generate roof plugin
This topic has been viewed 2488856 times and has 338 replies
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
captaincook
Country: France
Re: Generate roof plugin
Post by captaincook »
Et avec les murs et les fenêtres, c'est mieux.
Encore merci et bon week-end à vous, Dorin.
Post by dorin »
New version 4.7.1 (Francis)
News:
-improves the roof windows library (version 0.2)
--correct the previous and add a new one which could be used for holes on the roof face
--it could be used to do dormers more easy
-adapt the plugin code to use it
I'm not fully satisfied, so
TODO: improving the holes in the roof to be more accurate in all situations
Also on Source Forge
Suggestion: remove the previously versions.
@captaincook
Thanks for the inspiration. [>:D<]
@Keet
1. The mean of roof_window_deep I've explained at the last part of V.4.5 tutorial
2.
If I wanted to create a roof window, how do I determine what the roof_window_deep value should be? Or is it always 11.0?
It mean how much of the window height you decide should be inside the roof.
3. I need you to help me to improve (to be functional) and simplify (reduce number of) roof windows.
AceLemos
Country: Ireland
Post by AceLemos »
Hi @dorin, amazing plugin and great work to everyone! I just discovered it as I was struggling to create a roof for my house. However, I found an issue I can't see to be able to fix. My house has gables on each side and one side juts out with big windows. The roof generator doesn't seem to understand that so I tried messing around with it, but I have been at it for about 2 days now with no success.
This is the architect's render of the elevations:
When I draw a floor to render the roof, I do this:
So when I generate the roof, this is what I get (even after adjusting for the gables):
I can't seem to get the left side of the back to the shape the architect drew. I think it is because I don't have a part jutting out like in your tutorial. Any ideias?
Thanks for any help!
Cheers
Post by dorin »
Indeed. Is not an AI.
You need a trick. Something like this.
Add a very tinny part at the room (1 cm or even less). You will have to test.
I've zoomed to be more visible.
The roof generator.
Final result.
Good luck!
Post by Keet »
Maybe you can make it so that just adding a room point is enough without the 1cm break. I haven't tested it but that might already work.
Post by dorin »
You need 2 points to define an edge.
Need to be at least at 1 cm distance between them because the plugin clean the very close and collinear points.
AceLemos
Country: Ireland
Post by AceLemos »
Sorry for the dumb question, but what is a room point? Do you mean drawing a room in that space separate from the rest?
AceLemos
Country: Ireland
Post by AceLemos »
The roof generator.
Final result.
Good luck!
Thank you @dorin, this worked! I put an indent on that wall just in the room I used to generate the roof (not on the actual wall of the floor below it). Thank you. Just speculating here, would it be possible in the plugin to do reference points in the room or something like @keet said? I am not even sure what a room point is, but maybe that is something to go on for future versions?
Post by dorin »
I'm using a personal version (5.14) that can manipulate points and roof edges.
BUT
It is very difficult to use even for me.
I will have to find a better approach (if I live until then).
Post by dorin »
New version 5.0
News:
*keep the name given by the user after creation and modification;
*add point of view buttons
*add option to modify roof points/edges coordinates (one at a time);
*add features to:
**add(insert) a point(+P) on selected edge (by splitting the selected edge in two);
**delete a point(-P)(the end point) of selected edge (delete the selected edge);
*add a local undo/redo and reset mechanism
It have to look like this:
It will be available on Plugin manager when will be fixed.
Probably it need an updated manual. Will be on demand.
