I don't think that a NotSerializableException is due to an issue in the URL or a network error.
This exception is probably due to additional classes that you use in your saved homes that are not marked as Serializable. Don't forget to add a serialVersionUID field to your class(es) if you want to keep its compatibility when you'll add new fields and methods to it.
Need to deploy on Tomcat serer
This topic has been viewed 22918 times and has 41 replies
Re: Need to deploy on Tomcat serer
Thank You Puybaret for your Early reply...
