Sweet Home 3D 5.5
This topic has been viewed 318038 times and has 97 replies
Country: Paris, France
Re: Sweet Home 3D 5.5
Post by Puybaret »
The version 5.5 beta 10 (Java Web Start, Windows installer and Linux 64 installer) comes with an update of Hungarian translation and a new look for the Furniture modification dialog box with different labels for the rotation around the horizontal axes.
Hope you'll find it clearer [:)]
I propose also a second installer for Windows with the version 5.5 beta 11, to get your feedback about how Sweet Home 3D works with the latest Java Runtime Environment 1.8.0_144, one year later I decided to stuck on JRE 1.8.0_51 to fix the crash problems encountered by some of you (the installer of Sweet Home 3D version 5.5 beta 10 still comes JRE 1.8.0_51). To check if it works better, I hope some of you will have the patience to test whether Sweet Home 3D 5.2 still crashes, then try the new version 5.5 beta 11.
Thanks for your tests [:)]
If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b
Post by hansmex »
The Linux_64_installer links downloads a file called SweetHome3D-5.5.beta11-jre1.8.0_144-windows.exe.
Is that correct?
Post by Puybaret »
Sorry Hans, I fixed the link. Thanks for reporting the issue [:)]
Post by bdfd »
...If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b
Not chance !
It's now the second link for linux which is bad... [:D]
Post by Puybaret »
Fixed. Thank you. Bad luck [;)]
Post by okh »
Guess 'nothing to report' can also be a report [:)] Worked my way through the features and did some random editing, and Java Web Start seems to work beautifully under Win81. Thanks for the new features. ok
Post by bdfd »
Just a remark : Today, I use sh3d 5.5 beta11 in exe mode with success.
I won in using jlnp method with a good '.bat' file. [:D]
but i saw that the launched version was beta12 !
Is it the good ?
enkonyito
Post by enkonyito »
Is it possible for the camera to tilt along the Y axis like furniture?
EnkoNyito
Post by Puybaret »
Bdfd, I don't post a message at each update, moreover when it's about very small changes, but you're right, the current beta version is 12.
Enkonyito, I wonder what your request could be useful for.
enkonyito
Post by enkonyito »
Emmanuel, this "roll" option may not be very useful applied to the virtual visitor but in the case of a video rendering this would be an additional basic camera movement.
EnkoNyito
