Staircase generator plug-in
This topic has been viewed 1504782 times and has 72 replies
Xlance
Re: Advanced Staircase generator plug-in v4.0
Post by Xlance »
The Staircase Generator is a plug-in designed for Sweet Home 3D that allows users to create highly customizable 3D staircases. The tool features a comprehensive parameters menu for fine-tuning dimensions, structural elements, handrails, and midrails. It also includes an integrated 2D Shape Designer for creating custom handrail profiles.
Real-World Application: Whether you are an interior designer pitching a sleek, modern glass-railing loft, or an architect ensuring a multi-story traditional home meets building codes, this plug-in provides the exact geometrical control you need.
https://sourceforge.net/p/sweethome3d/plug-ins/60/
Windows 64bit | Intel i7 | 8GB Ram | SH3D 7.5 + Plugins
deschmal
Post by deschmal »
Hi Xlance,
v4.0 looks really great and I love the more detailed options!
However, one flaw that I found is that when you select "U shaped", the generator will create a "U shaped with bottom landing instead" so something seems to be linked incorrectly there.
Thanks for the nice work!
deschmal
Post by deschmal »
The error is on line 441:
Code: Select all
				return createUShapedStaircaseShapes(stairCount, firstStairCount, 1, turnStairCount, stairWidth, stairDepth, stairHeight, treadOffset, treadThickness, true, riserThickness,
should be
Code: Select all
				return createUShapedStaircaseShapes(stairCount, firstStairCount, turnStairCount, turnStairCount, stairWidth, stairDepth, stairHeight, treadOffset, treadThickness, true, riserThickness,
Xlance
Post by Xlance »
@Dorin
@deschmal
Fixed glitch and uploaded corrected plugin as per @deschmal
with organised code as per @Dorin on:
Thank You :-)
deschmal
Post by deschmal »
Thanks, seems to be working fine :-)
knoxsooner
Country: United States
Re: Staircase generator plug-in
Post by knoxsooner »
Where do I find the new 'generate staircase'? I don't have a menu titled 'Tools'.
Xlance
Post by Xlance »
Has anyone created advanced stairs using v4.0 of the generator ?
It would be really of benefit to see users' creations to help guide further development [:)]
Xlance
Post by Xlance »
sjb007
Post by sjb007 »
Cool! One quirk of British building regulations: A landing area must at minimum be a square, each side equal to the width of the stair. i.e. the middle landing of your Y shaped stair would be illegal. To make it legal you'd need to overlay the 3 squares in the smallest space, if that makes sense.
Xlance
Post by Xlance »
@sjb007
OK [:)] Refer to updated Models
Type T
https://ibb.co/8QRzw5T
Type inv T
https://ibb.co/SYyMVgz
Type Y
https://ibb.co/YBJTNp4B
Type inv Y
https://ibb.co/Qvk51v69
