Sweet Home 3D 5.5
This topic has been viewed 318008 times and has 97 replies
Re: Sweet Home 3D 5.5
Post by bdfd »
qythyx
Country: Japan
Post by qythyx »
I just tried to render a video with this version and it didn't work at level 1 & 2, basically nothing happens. When I try level 3 or 4 it works fine.
Post by bdfd »
No problem for me in these levels.
But you:
OS ?
RAM ?,
CG ?, ...
qythyx
Country: Japan
Post by qythyx »
This isn't really related to the new version, but I thought I'd mention it here anyway. I have a MacBook Pro with the LG 5k monitor. When running SH3D on that monitor it is quite slow. It seems that's because of the very high resolution. Interestingly it's slow not just operations that involve the main layout screen, just bringing up normal dialog windows is slow to the point that I can see the dialog components being drawn in the window. If I reduce the size of the window, or adjust the resolution settings, then it does get better, but obviously I'd like to use the full resolution if possible.
Again, this isn't new to the new version.
On a side note, is there a jar-only build of the new version so I can run it with Java 8 on MacOS?
Thanks,
Post by bdfd »
... It seems that's because of the very high resolution...
What is your "high resolution" ?
What is the weight of your used file ?
Country: Paris, France
Post by Puybaret »
Sweet Home 3D 5.5 was released today (including a Jar executable version, but without the portable version yet).
Thanks to you all for your feedback and help! [:)]
Post by okh »
Congratulations on the new release! Lots of interesting improvements as usual. Thanks. ok
Post by bdfd »
At this time, 5.5 works fine !
qythyx
Country: Japan
Post by qythyx »
The builtin display is 2880x1800 and the external monitor is 5120x2880. I usually show the floor plan on the external monitor and the 3D view on the builtin.
The file is about 30MB.
Country: Copenhagen, Denmark
Post by Ceciliabr »
There seems to be a problem with creating pictures and videos at the two lowest qualities.
I have tried with OSX Sierra 10.12.6, and with Yosemite 10.10.5.
cec
