Stonewalls Texture
This topic has been viewed 3235 times and has 2 replies
Diana57
Country: United States
Stonewalls Texture
Post by Diana57 »
I am trying to design a patio and I have it done except for the texture on top of the stonewall.
I created a wall 3 feet high by 2 feet thick and I added stone texture to the sides of the wall but I haven't figured out how to add texture to the top of the stonewall. I created the patio by using the "create room" tool and adding texture "Wall - Old Grey Ttones" and for the stonewall I modified the wall thickness and height and then added texture "Wall - Old Stones" to the sides of the wall.
So my question is it possible to add texture to a top of a wall or should I used another way to make the stonewall?
Re: Stonewalls Texture
Post by hansmex »
You can't add textures to the top of walls.
Instead you could use boxes, where you can add individual textures to each side.
Diana57
Post by Diana57 »
Thank you very much!
I started to think that I was barking up the wrong tree using walls but I didn't know what else to use.
