How To: Sunlight through window
This topic has been viewed 3314 times and has 2 replies
daytooner
Post by daytooner »
Basic question: I have a window in my model, and I would like to see what the room looks like with and without sunlight coming through. Right now, I added an incandescent light source on the outer side of the window, and made it the same width as that. And I know that I can change the amount of light (power)coming from that source, for different times of the day.
Is this the best way to do this? When I take a photo of the room with different powers, I don't see too much difference (obviously there is a significant difference between full power and no power).
Any help appreciated.
TIA
ken
On a side note:
This is a bathroom that I want to remodel. The window sets on one side of the room above a bathtub. There is enough light through that window to light up the room (during the day). On the opposite wall is a row of lights above a mirror. I am replacing the tub with a shower stall. And when I did the first model of this, I could tell that: 1) during the day, the rest of the room became dark, since the new stall would block light from the window into the rest of the room; 2) at night, even with the lights on, the shower stall was very dark. I would never have noticed this unless I had used sh3d to do a model of the room.
So, thanks to all of you - past, present, and future - who have created this great tool!
Re: How To: Sunlight through window
Post by hansmex »
As far as I know, in SH3D, glass filters out more light than in real life.
You can replicate the sun settings by (1) orienting the compass correctly and (2) setting date and time.
daytooner
Post by daytooner »
Thanks. What I expected.
But another question on a related topic. How do I model a light fixture that includes the light (and power level)? There are several lamps like this. I have modeled a light bulb with glass material in blender, imported it into sh3d. But if I put a light source inside of it, no light shows. I guess sh3d probably doesn't know the material is transparent. I made the glass material invisible, which worked, but I lost the shape, which I would like to keep. Would a texture of semi-transparent work? Say an alpha channel of 25%.
Thanks for your help.
ken
