Hello !
Please how do I set up the angle between two walls ? See the linked picture - I have to create walls based on the floor plan.
https://drive.google.com/file/d/1ECSigH ... sp=sharing
Thanks.
How to set up teh angle between two walls ?
This topic has been viewed 1276 times and has 2 replies
miro_ilias
- Country: Slovakia
Re: How to set up teh angle between two walls ?
I take it the problem is the snapping to fixed angles? It is because you have magnetism set on. In the screenshot you can see an icon of a magnet. Click that to disable magnetism. You can then drag your endpoints to any angle.
miro_ilias
- Country: Slovakia
Thanks ! This helped, my problem is solved.
