When I export to PDF, I get a super low resolution version of the floor plan.
So far the best way I've found is a pan-and-scan desktop from
https://gimespace.com/products/desktop-extender.html
Then create a big window for SH3D, and screen capture.
Is there a better way to get a higher resolution bitmap?
Or a way to get a full resolution structured export, not just a bitmap?
How can I get a high resolution bitmap of a 2D floorplan? Or true SVG/PDF?
This topic has been viewed 1984 times and has 2 replies
- Daniels118
- Country: Italy
Re: How can I get a high resolution bitmap of a 2D floorplan? Or true SVG/PDF?
Have you tried the SVG export? (Plan > Export to SVG format)
Ah, SVG update works. I had expected that under File-> and missed it under Plan->
Thanks.
Thanks.
