Sample plugin does not start
This topic has been viewed 6485 times and has 4 replies
Questions about extending features and developing plug-ins [img]http://www.sweethome3d.com/images/flags/en_small.gif[/img]
cungchoi
Post by cungchoi »
I followed exactly the Plugin development guide and created VolumePlugin.jar in plugin folder.
However when I opened the main Sweethome3d, it stays the start up picture forever.
I tried changing JRE package (I have v6, v7 on my Win7) but no help.
Any ideas? thanks
Country: Paris, France
Re: Sample plugin does not start
Post by Puybaret »
Check the console, there must be a stack trace that appears in it.
cungchoi
Post by cungchoi »
thank you, I think I did a wrong thing to run the Sweethome3d.exe instead of its Jar version. Will try again.
Post by Puybaret »
Plug-ins can run from Sweethome3d.exe too, but in case of problems, you should rather use the Jar version to check the console.
cungchoi
Post by cungchoi »
Right, I think my exe file is not up to date. Fine now though.
BTW, I modified your plugin Compute Walls Surface for my purpose and just for it (being messy of course), still I post it here if anyone bother to test or use it.
don't know how to attach a file
Code: Select all
//version 25 Dec 2014
//- added ability to approximate curved walls
//- added ability to work for multilevel building
//- corrected slope walls
//- filter openings substractions by Doors & windows only
//- approximate doors & windows positions to prefer more inclusions. CAUTION: may have side effects when a door or windows is in vicinity of more than one wall on any level
package com.eteks.calculateWalls;
import java.awt.geom.Point2D;
import java.lang.reflect.Method;
import java.util.ArrayList;
import com.eteks.sweethome3d.model.HomePieceOfFurniture;
import com.eteks.sweethome3d.model.Selectable;
import com.eteks.sweethome3d.model.Wall;
import com.eteks.sweethome3d.plugin.Plugin;
import com.eteks.sweethome3d.plugin.PluginAction;
import javax.swing.JOptionPane;
class CalculateWallsAction  extends PluginAction {
    private final Plugin plugin;
    public CalculateWallsAction(ClassLoader loader, Plugin plugin){
    	putPropertyValue(Property.NAME, "Compute walls' area");
        putPropertyValue(Property.MENU, "Tools");
        this.plugin = plugin;
        // Enables the action by default
        setEnabled(true);
    private void showInfo(float size) {
        String message = "The walls' area currently is: "+size+" m\u00B2.";
    	if(size == 0)
    		message = "Please select at least one wall.";
        JOptionPane.showMessageDialog(null, message);
    private boolean inWall(Wall w, float x, float y)
    	//if(x >= Math.min(w.getXStart(), w.getXEnd()) && x <= Math.max(w.getXStart(), w.getXEnd()) && y >= Math.min(w.getYStart(), w.getYEnd()) && y <= Math.max(w.getYStart(), w.getYEnd()))
      float cmpRate = 0;
   	//generalize- just one end near the wall surface, there are two cases:
   	//case 1: an arc wall
      if(w.getArcExtent() != null)
    	  float [] arcCircleCenter;
    	  float arcCircleRadius;
    	  try{
	          Method m = Wall.class.getDeclaredMethod("getArcCircleCenter");
	          //m.invoke(d);// throws java.lang.IllegalAccessException
	          m.setAccessible(true);// Abracadabra
	          arcCircleCenter = (float[]) m.invoke(w);// now its OK
	          arcCircleRadius = (float)Point2D.distance(w.getXStart(), w.getYStart(),
	    	          arcCircleCenter [0], arcCircleCenter [1]);
		      cmpRate =(float)Point2D.distance(x,y,arcCircleCenter [0], arcCircleCenter [1])/arcCircleRadius;
	      } catch (Exception e) {
	          e.printStackTrace();
      else
	      float dist2Start = (float)Point2D.distance(x,y,w.getXStart(), w.getYStart());
	      cmpRate = (dist2Start + (float)Point2D.distance(x,y,w.getXEnd(), w.getYEnd()))/w.getLength();
	   if((cmpRate > 0.9)&&(cmpRate< 1.1)) return true;
    	return false;
    @Override
    public void execute() {
    	float size = 0;
    	ArrayList<Wall> walls = new ArrayList<Wall>();
    	for(Selectable sel : plugin.getHome().getSelectedItems())
    		if(sel instanceof Wall)
    			Wall wall = (Wall) sel;
    			//if(wall.getArcExtent() == null)
				walls.add(wall);
    			size += (wall.getHeight() + ((wall.getHeightAtEnd()==null)? wall.getHeight():wall.getHeightAtEnd()) )*wall.getLength()/2.0;
    	    	//substracts openings
    			for(HomePieceOfFurniture furniture : plugin.getHome().getFurniture())
	        	if(furniture.isDoorOrWindow()
	        			&& wall.isAtLevel(furniture.getLevel())
	        			&& inWall(wall, furniture.getX(), furniture.getY()))
        			size -= (furniture.getHeight()*furniture.getWidth());
    	size /= 10000;
    	showInfo(size);
