Hi, I'm trying to convert from the exported file in Sweet Home (obj) to Collada file .dae , but in process I've founded some problems:
Using this online tool , I upoload both .obj and .mtl files, and the .dae file is generated but without color.
Using meshlab, he gives the follow error:
Error encountered while loading file:
habitacion.obj
Error details: Identical vertex indices found in the same faces -- faces ignored
Then the obj is loaded, but when I try to export as .dae then the color is lost.
Using Maya, he gives the follor error:
Error: line 0: OBJ file line 616: index out of range for face creation.
Error: line 0: Error reading file.
and stops the import.
can somebody help me with this problem? the file is in this link
obj file to dae file strange errors
This topic has been viewed 7733 times and has 1 replies
Re: obj file to dae file strange errors
Importing your OBJ files work in Sweet Home 3D, Blender and Wings3D and exporting to DAE format worked in Blender and Wings3D.
So I guess meshlab and Maya aren't able to reuse a vertex of a shape in another shape (here it's vertex #184). Strange, it seems to be a good way to optimize OBJ files size, and I don't think OBJ format description says it's forbidden.
