Multiple Level - Virtual View
This topic has been viewed 2868 times and has 1 replies
richardm
Country: Lincolnshire, England
Post by richardm »
Having constructed two levels I am having problems with the 3D view (Virtual View). The section of roof which was created in Level 0 but modified in level 1 (I am creating a loft conversion) is not visible if I do a virtual view at level 0. None of the 'furniture' (these are rafters etc created through the ubiquitous box) are not rendered.
If I switch to level1 everything is rendered but the viewpoint is 2600 mm above ground level when setting the virtual visitor's eye level to 100mm.
Any advise greatly appreciated.
richardm
Re: Multiple Level - Virtual View
Post by richardm »
Oops - found solution now - need to turn on view all levels - apologies for the waste of time.
