Hello.
I do not want to run SWEETHOME on Windows 7.
Do not you happen to know why?
Thank you in advance for your reply
Problem in Windows 7
This topic has been viewed 4194 times and has 4 replies
Re: Problem in Windows 7
Hello,
You probably mean that you can't run Sweet Home 3D, right?
What message do you get?
no message coming up.
just clicks will not start.
Did you try the installer or the Java Web Start version?
Do you use a 64 bit or 32 bit version of Windows 7?
WINDOWS 7 64 bit / ASUS GTX 1050 / MSI 785GM-E51
DOES NOT PROVIDE ANY VERSION
