Using Mint 19
I installed Sweethome3d in the /opt directory.
Where do I install the .eteks folder in order to use the plugins.
Also if I installed this through the software channel it creates a snap file, where would I install the .eteks folder in that case.
Thanks
carltonb
Where to install .eteks
This topic has been viewed 4675 times and has 2 replies
Re: Where to install .eteks
Run once Sweet Home 3D and modify something in its preferences to let the software create the [font=courier new].eteks/sweethome3d[/font] folder in your home directory. Then you can create a subfolder named [font=courier new]plugins[/font] in [font=courier new].eteks/sweethome3d[/font].
Thanks worked exactly as you stated.
