High priority Dimensioning/Bemaßung
This topic has been viewed 3270 times and has 1 replies
orwe8
Country: Germany
Post by orwe8 »
Hallo,
als Maßeinheit habe ich mm eingestellt. Die Bemaßungen werden jetzt in mm angezeit, jedoch auf cm gerundet. (Statt 5432 mm wird 5430 angezeigt). Wie kann ich die rundung abschalten?
Hello,
I have set the unit of measurement to mm. The dimensions are now set in mm, but rounded to cm. (5430 is displayed instead of 5432 mm). How can I switch off the rounding?
Country: Paris, France
Re: Dimensioning/Bemaßung
Post by Puybaret »
The rounding depends on the current zoom factor. Zooming in will let you create dimensions with higher precision. You may also type directly the length you want with <enter> key (see included help about dimensions).
