Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin |
| Print at Sep 26, 2026, 4:55:09 AM |
| Posted by upsetter21 at Jan 26, 2023, 8:03:27 PM |
Re: Generate roof plugin Hello: the GenerateRoof Plug-in shows up in my Tools menu, but when I click nothing happens. I've been trying to figure out how to put a roof on my project for weeks. Today I am finally going crazy! |
| Posted by dorin at Jan 26, 2023, 8:26:50 PM |
Re: Generate roof plugin Probably it appear grayed. Select a room and try again. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by dorin at Jan 27, 2023, 8:03:50 AM |
Re: Generate roof plugin Follow STRICTLY this steps. I will not writing twice. 1. Open a new file, draw approximately your walls (it is only for learning so, the accuracy is not so important). 2. Draw a room around walls which represent the roof projection. ![]() 3. Select that room ![]() 4. Tools -> Generate roof... ![]() 5. You should see something like this ![]() 6. Select the triangle faces (4 in this case). Keep Ctrl pressed to do this. ![]() 7. Set their slope to 90 degrees ![]() 8. Check the Invisible checkbox ![]() 9. Select two faces in front of the house ![]() 10. Set their slope to 33 degrees ![]() 11. Do the same with faces from the back side of the house ![]() 12. Click somewhere outside the roof and you should see this. Click OK. ![]() 13. On plan, Right click on selected roof and go to Modify furniture... -> Materials -> Modify... ![]() 14. Select all upper faces ![]() 15. Set their texture ![]() 16. Select border and lower ![]() 17. Set preferably a different texture ![]() 18. This could be the result ![]() If you are not completely satisfied with the result you could select the generated roof and go back to Tools -> Generate roof. The plugin it is able now to do this thanks to Daniels118. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by VeroniQ at Jan 28, 2023, 12:28:57 AM |
Re: Generate roof plugin Whaou, Dorin, thank you very much, it is very clear!! |
| Posted by Vinci68 at Jan 28, 2023, 11:59:12 AM |
Re: Generate roof pluginThank you Dorin for your patience in explaining, in great detail, how these plugins work. It helps a lot of beginners... like me! |
| Posted by dorin at Jan 28, 2023, 8:42:27 PM |
Re: Generate roof plugin Thank you VeroniQ and Vinci68! Probably you two are the only one who read it all. Mainly those who don't need more explanations (VeroniQ). The rest of the people stop reading at point 3 or 13. It appear it is a YAUT (Yet Another Useless Tutorial). ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by Keet at Jan 28, 2023, 9:01:18 PM |
Re: Generate roof plugin Definitely not a useless tutorial. You have to understand these basic steps before you can start with more complex roofs and start to combine different roofs if a single roof is impossible. Good work! ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by crackwood01 at Jan 30, 2023, 8:51:07 PM |
Re: Generate roof plugin Hi Dorin, i would like to do a 5 degree slope, but roof generator starts at 15. How can i do it |
| Posted by dorin at Jan 30, 2023, 9:18:14 PM |
Re: Generate roof plugin You can't now. We work on this so, in the next version, we hope it should be possible (from 1~179). We still testing it. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by ndorigatti at Feb 2, 2023, 8:01:24 AM |
Re: Generate roof plugin nah, I red it and appreciate a lot, even if I already used the plugin with success, i found an additional step i wasn't doing. Unfortunately I'm one of those who reads everything but rarely comments, so sorry for that, but your work is a high level one and really appreciated. I suggest to save it as a PDF, put it online and add in the plugin notes/description so the ones using plugin manager can see a "GUIDE" immediately! Thanks for your development and infinite patience. |
Current timezone is GMT Sep 26, 2026, 4:55:09 AM |
