Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin |
| Print at Sep 23, 2026, 12:34:32 PM |
| Posted by Daniels118 at Jan 21, 2022, 4:15:56 PM |
Re: Wirings pluginWarning! I discovered a bug using wirings with levels. When you draw wirings they are correctly assigned to the active level. However when you save the file the level of each wiring is not saved. So, when you reopen the file, the wirings are all added to the active level, regardless of the level they were originally. This bug will be fixed in the next release, a popup message will inform you if your file contains such wirings. Apologize me for the inconvenience. ![]() |
| Posted by Daniels118 at Jan 24, 2022, 11:35:17 AM |
Re: Wirings plugin Version 1.2 released! List of changes:
| Posted by Daniels118 at Mar 29, 2022, 12:53:18 AM |
Re: Wirings pluginWARNING: the following message contains advertising, Have you ever wanted to add wirings to your home, but you got headache with 3D drawing? You don't have to worry anymore! The Wirings plugin is going to enrich with a new feature for automatic wirings creation! -- END advertsing -- The wirings will be added automatically between furnitures that share the same tag. I count to release an alpha version very soon. You can watch it in action here: https://youtu.be/bsenkUxNHCs Comments are appreciated ![]() |
| Posted by hansmex at Mar 29, 2022, 6:39:57 AM |
Re: Wirings plugin That looks very nice. Especially the elasticity is impressive! :-) H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Daniels118 at Apr 4, 2022, 5:21:47 PM |
Re: Wirings plugin Thank you Hans! I decided to throw away the tags system because it was too cumbersome. Instead, a simple select-and-click system makes things much more easier. New features also include:
https://youtu.be/Z_XFq4QaD8E |
| Posted by Daniels118 at Apr 5, 2022, 10:20:05 PM |
Re: Wirings plugin Version 4.0 alpha released Warning: this is an alpha version, it is unstable and may cause crashing or data loss. Test it at your own risk. This version brings the capability to link 2 or more objects automatically. Just select the objects and click on Link selected furniture from the Tools menu, or use the button on the toolbar. If you move a linked object the links will follow the object in real time. If 2 or more wirings are attached to the same object, a different offset is applied to each wiring to avoid overlapping. ![]() Download from SourceForge or using the Plugin manager. |
| Posted by mirakels at Apr 14, 2022, 7:03:13 PM |
Re: Wirings plugin I played a bit with version 3 of the plugin. I works reasonably good! A few remarks - when I change the thickness of the polyline it does show the change in plan view, but not in 3D view. - when I use the 'edit points' and delete or add a point from a wire (by accident or deliberate), I cannot add/change any wires in 3D-view anymore. I guess that this last one is because 'edit points' degrades a wire to a normal polyline... It would be great if Puybaret could work with you to integrate this plugins functionality into the main program (and hence support a height/elevation parameter for polyline points)! That would also solve my issue as described in the wishlist forum ;) Thanks for the good work Daniels118 |
| Posted by Daniels118 at Apr 15, 2022, 10:01:29 AM |
Re: Wirings plugin Hi mirakels, thank you for your feedback. - you're right, the thickness in the 3D view doesn't update, it will be fixed in the next release. - the Wirings plugin has its own function to remove and add points directly from the 3D view (see the user guide available from the help menu). Version 3.0 has a bug that occurs when you try to add a point, but this has been already fixed in version 4.0 alpha. In the next release I'll try to make the wirings compatible with the Advanced editing plugin. Of course you still won't be able to edit the elevation, but at least wirings won't break anymore. Although I could integrate the polyline elevation within a plugin, I think this is a feature that should be handled by the main program, or at least by the Advanced editing plugin. What I could do is to add an offset parameter so that wirings can be pushed within floors, walls, and ceilings. This feature would be available only for automatic wirings, since this would break the manual editing. You can try automatic wiring by installing version 4.0 alpha, I would be happy to receive your feedback on this new feature. |
| Posted by Helios1977 at Aug 4, 2022, 9:42:32 AM |
Re: Wirings pluginDear All! Try to test this miracle plugin and all for me clear and very useful... But, I can't open table with polylines length. Tools -> Wiring Toolbox ... Nothing is appeared( Language changing not give any effect. Might be some plugin is not installed? Pan 3D + Wiring + Advanced Editing plugins are installed Please help me to get this table with wiring length |
| Posted by Daniels118 at Aug 4, 2022, 4:25:36 PM |
Re: Wirings plugin Hi Helios1977, it seems the toolbox has broken with some upgrade, I'll try to fix it as soon as possible. |
Current timezone is GMT Sep 23, 2026, 12:34:32 PM |
