Print at Sep 23, 2026, 11:52:52 AM
Posts: 106   Pages: 11   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Posted by Daniels118 at Jul 17, 2023, 9:31:07 AM
Re: Wirings plugin
Hi 241177793, there isn't any wrong with your installation, you just found a bug in the plugin. It will be fixed by tomorrow.
You don't find the 3rd coordinate because wiring nodes are just a side effect, the real wiring data is stored in custom properties named "it.ld.sh3dplugins.wirings.Wiring@unique_id".
Posted by Daniels118 at Jul 17, 2023, 5:17:26 PM
Re: Wirings plugin
The length bug has been fixed, version 4.3 just released!
Download from SourceForge or using the Plugin Manager.
Posted by 241177793 at Jul 18, 2023, 1:03:22 PM
Re: Wirings plugin
Many thanks to you!
Posted by IvanDiaz at Aug 1, 2023, 10:29:14 PM
Re: Wirings plugin
Good morning Daniels118, is there any way to make it possible to edit the measurement lines from a pop-up window or in the 3d plane itself? Editing the line from the 2d plane is very difficult, especially if the line made has been crooked. smile
Posted by Daniels118 at Aug 3, 2023, 5:05:56 PM
Re: Wirings plugin
@IvanDiaz
There is a bug that prevents selecting wirings from the plan view, it will be fixed in the next release and I will also add a method to edit the wiring properties directly from the 3D view.
Posted by Daniels118 at Sep 3, 2023, 11:38:33 AM
Re: Wirings plugin
Version 4.4 beta 2
Compatible with SweetHome3D 7.2 and Pan 3D View 4.0 beta.
Requires Pan 3D View 4.0 beta or later.
Allows wiring selection from the 3D view (Wiring tool must be disabled)
Once selected, the wiring can be edited using CTRL+E available.
Posted by JBRI at Nov 16, 2023, 2:33:21 PM
Re: Wirings plugin
After loading the wiring plugin Sweet home 3d will not launch. It says I must load the Pan plugin first but I can't launch the program now!
I've tried to delete everything and reinstall several time, no luck!.
Please help!!! crying
Posted by Keet at Nov 16, 2023, 8:40:45 PM
Re: Wirings plugin
If you are on Windows:
Go to "C:\[USER]\eTeks\Sweet Home 3D" with your file manager. There should be a folder for the plugins. Delete the wirings sh3p file and you can start Sweet Home 3D again. Now first install the Pan3DView plugin before you reinstall the wiring plugin.
I suggest that you install the Plugin Manager as mentioned in the post right before yours and use that to install other plugins.
On Linux the plugin directory is /home/[USER]/.eteks/sweethome3d/plugins. That is a hidden directory so don't forget to switch your view in the file manager to view hidden files. (Notice the . before 'eteks', hidden files/directories start with a point on Linux.)
On Apple? I have no idea.
Posted by Puybaret at Nov 20, 2023, 5:38:50 PM
Re: Wirings plugin
If you use Windows, the plugins folder is in C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D, and not in C:\user\eTeks\Sweet Home 3D.
If you don't see AppData folder, try suggestions here.
Posted by Keet at Nov 20, 2023, 8:53:12 PM
Re: Wirings plugin
I better refrain from remarks concerning Windows in the future laughing
The wrong path I mentioned came from another forum post but apparently MS has changed them over the years. I haven't used Windows since XP so I had no idea about those changes.
