Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: problem with make a Photo |
| Print at Oct 3, 2026, 6:23:02 PM |
| Posted by centi at Apr 16, 2013, 5:06:38 PM |
problem with make a PhotoHi, i have Problem with draw up a Photo. SHD start to make a picture and a in a few seconds are the button Save aktivate but the picture ist not redy, only a view quader with circle RGBY inside on the picture. Where ist the Problem. My Processor is i5 2500 K and the Grafickard ist the Intel 3000 HD (inside proc). Thanks for Help. P.S: Sweet Home is a great program! thanks. Peter |
| Posted by centi at Apr 17, 2013, 11:28:05 AM |
Re: problem with make a Photo [IMG]http://s1.directupload.net/images/130417/kglnwjcl.png[/IMG] now you see it :-( whats wrong? Thanks for Help Peter |
| Posted by Puybaret at Apr 17, 2013, 12:38:23 PM |
Re: problem with make a Photo Please send me your file. It's been a long time since this kind of bug wasn't reported, but maybe you found a new special case. What version of Sweet Home 3D do you use? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by centi at Apr 17, 2013, 1:54:21 PM |
Re: problem with make a Photo Hi, thx for Answer. my sweethome Version is Sweet Home 3D ® Version 4.0, DirectX, Java Version 1.6.0_43. What of File will you have? .exe or? Peter |
| Posted by Puybaret at Apr 17, 2013, 2:24:43 PM |
Re: problem with make a Photo Please send me the SH3D file of your home project, not the exe file. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ludideco at Apr 23, 2013, 1:14:56 PM |
Re: problem with make a Photo same problem here !!!! :/ |
| Posted by Puybaret at Apr 23, 2013, 4:56:29 PM |
Re: problem with make a Photo centi's issue was solved by increasing the max memory used by the program. Hope this will help. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Ludideco at Apr 23, 2013, 5:56:53 PM |
Re: problem with make a Photo Thanks ! Tryin to but i dont understand how you can write something in a folder... " write the max memory Java option in that file, for example -Xmx1024m" |
| Posted by Puybaret at Apr 23, 2013, 7:02:15 PM |
Re: problem with make a Photo You can use this file if you want to. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by centi at Apr 24, 2013, 3:41:10 PM |
Re: problem with make a Photo hi, yes that was the problem. THX for your help Puybaret! download as first SweetHome3D-4.0.jar not forget those! I just made a start.bat with this content: " @ echo off Java -Xmx4096m -jar "C:\Program Files (x86)\SweetHome3D\SweetHome3D-4.0.jar" exit " and again a problem lass in this world Peter |
Current timezone is GMT Oct 3, 2026, 6:23:02 PM |
