Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: problem with make a Photo |
| Print at Oct 2, 2026, 8:21:07 PM |
| Posted by Jusmara at Apr 24, 2013, 10:46:55 PM |
Re: problem with make a Photo I hope someone here can help me. I know enough to know that I need to increase the memory usage for my program. I have the 64 bit java and sweethome.jar downloaded. My proplem is that I am a complete novice and I don't understand the instructions in the FAQ regarding......execute the java -Xmx4096m -jar path\to\SweetHome3D-4.0.jar command for 4 GB.......How exactly do I accomplish this? Can someone please give me step by step instructions? I am running windows 7 on my machine. I need this quick. My project is for a college course. It is due Monday. I have finished my design, but it is large and has a lot of furnishings. The program keeps locking up. |
| Posted by centi at Apr 25, 2013, 8:26:28 AM |
Re: problem with make a Photo Hi Jusmara, my Email was blocket by your Provider!. Peter |
| Posted by Puybaret at Apr 25, 2013, 8:44:44 AM |
Re: problem with make a Photo centi, couldn't you explain in the forum? It may be helpful for other users one day... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by centi at Apr 25, 2013, 9:00:30 AM |
Re: problem with make a Photo Hi, Step by step (windows7 64bit): download the file SweetHome3D-4.0.jar and save in to Folder "C:\Program Files (x86)\SweetHome3D\" right mouse Key on Desktop -> new text file -> start.txt rename start.txt into start.bat edit the file and write the following into: @echo off {Java -Xmx4096m -jar "C:\Program Files (x86)\SweetHome3D\SweetHome3D-4.0.jar"} exit (between the {..} have to be in one line and without { }.) save the file. redy! double-click this file and sweet home starts. In this way, makes Sweet Home 3D no Problems. Peter |
| Posted by Jusmara at Apr 25, 2013, 9:41:49 AM |
Re: problem with make a Photo Hello Centi and Emmanuel. Thanks for trying so hard to help me, but I am still a little bit lost. I have the sweethome file downloaded and saved into the correct folder (C:\Program Files (x86)\SweetHome3D) I am missunderstanding your instructions at the point that you say "right mouse Key on Desktop" I don't know exactly what you mean. If you mean to right click the mouse on my desk top, a window appears with a list of options starting with "view" and ending in "personalize" I don't think that is what you intend for me to do. If I understand your instructions, I need to find the file called "start.txt" then rename it "start.bat" I then open that file and write @echo off {Java -Xmx4096m -jar "C:\Program Files (x86)\SweetHome3D\SweetHome3D-4.0.jar"} exit Exactly as you have it above with the text between the {} all in one line but without the {}. Is that correct? If so, the first thing I need to know is exactly where and how to find "start.txt" |
| Posted by centi at Apr 25, 2013, 10:07:36 AM |
Re: problem with make a Photo Hi, yes I mean Desk top. Sorry, my Windows talk German ;-) right mouse key on free place on desktop, then new, and then textdokument. Then you have a new file on desktop with name what you want. You self can give the Name for this file, for example start.txt or sh3d.txt or what you want. regards Peter |
| Posted by Jusmara at Apr 25, 2013, 10:24:05 AM |
Re: problem with make a Photo Ok Peter. I have made the file and it is on my desktop. I named it sweethome start. When I double click it. It just opens the file and I see this. @echo off Java -Xmx4096m -jar "C:\Program Files (x86)\SweetHome3D\SweetHome3D-4.0.jar" exit Nothing actually happens other than the file I created is now open and I have the opportunity to change the code. Do I need to move the file somewhere else, or is the above code incorrect somehow. What you see here is copied and pasted from the file I created on my desktop. |
| Posted by centi at Apr 25, 2013, 10:28:53 AM |
Re: problem with make a Photo Hi, i wrote rename this file.txt in file.bat... that's all regards Peter |
| Posted by Ludideco at Apr 25, 2013, 11:59:57 AM |
Re: problem with make a Photo Now sweet home closes automatically ! grrrrrrrr ! |
| Posted by centi at Apr 25, 2013, 1:33:26 PM |
Re: problem with make a Photo while you work on sweet home don't close the black window. leave this window open or minimize it. and you will be happy :-) ragards Peter |
Current timezone is GMT Oct 2, 2026, 8:21:07 PM |
