Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Problem of executing the source code on eclipse |
| Print at Sep 26, 2026, 6:53:51 AM |
| Posted by choppyleo at Aug 11, 2014, 1:01:13 PM |
Problem of executing the source code on eclipse I followed the instructions on Readme but when I executed the program I obtain the error messages as shown below. Can someone advice me on what to do at this stage Exception in thread "main" java.io.FileNotFoundException : -Djava.ext.dirs=C:\Windows\System32\lib\windows\i386;lib (La syntaxe du nom de fichier, de répertoire ou de volume est incorrecte) at java.io.FileInputStream.open (Native Method ) at java.io.FileInputStream.<init>(Unknown Source) at java.io.FileInputStream.<init>(Unknown Source) at org.freehep.util.io.ASCII85InputStream.main (ASCII85InputStream.java:147 ) |
| Posted by Puybaret at Aug 11, 2014, 1:11:21 PM |
Re: Problem of executing the source code on eclipse You mixed up "Program arguments" and "VM arguments" in eclipse run configuration. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by choppyleo at Aug 11, 2014, 1:24:29 PM |
Re: Problem of executing the source code on eclipse Thanks, I have corrected that and now seeing this: Usage: ASCII85InputStream filename |
| Posted by sree.arun.kr at Aug 11, 2014, 1:41:54 PM |
Re: Problem of executing the source code on eclipse Can you explain how to build runnable jar (sweethome3d.jar=2.55MB)or an exicutable jar(sweethome3D.jar=22MB)or sunflow.jar-0.07.3i?. [* Don't know about programming not only java but downloaded apache-tomcat7.0.zip +ant1.94.zip +JDK1.7 but next step ...? ] Intreasted to learn and tweak. Thanks in advance. ![]() ---------------------------------------- ![]() |
| Posted by choppyleo at Aug 11, 2014, 2:06:33 PM |
Re: Problem of executing the source code on eclipse I think I know how to creat that but I don't know how your reply is helpful to my question. Thanks |
| Posted by sree.arun.kr at Aug 11, 2014, 2:17:39 PM |
Re: Problem of executing the source code on eclipse Importing source and editing java code is success then now looking for a 10-20 step tutorial from a developer/programmer. All kinds of tips are welcome. ![]() ---------------------------------------- ![]() |
| Posted by choppyleo at Aug 11, 2014, 2:25:34 PM |
Re: Problem of executing the source code on eclipse Please sree.arun.kr I don't get clearly what you are driving at cos I asked a question and maybe I don't understand you but I still don't see how your reply helpful to my question on trying to execute sh3d on eclipse. Thanks |
| Posted by sree.arun.kr at Aug 11, 2014, 2:35:52 PM |
Re: Problem of executing the source code on eclipse Question is simple When I get the SH3D sourcecode then how to build a jar application using Eclipse.? If you are successfull to create a sweethome3d.jar then share the methods you used. Thats it. ![]() ---------------------------------------- ![]() |
| Posted by choppyleo at Aug 11, 2014, 2:57:50 PM |
Re: Problem of executing the source code on eclipse If you have already imported the source code on eclipse(but if not then follow the step of the Readme file). After doing so then follow the steps on then site: http://www.wikihow.com/Create-an-Executable-File-from-Eclipse Good Luck |
| Posted by sree.arun.kr at Aug 11, 2014, 3:29:18 PM |
Re: Problem of executing the source code on eclipse Sourcecode importing and editing is done but exporting an exicutable jar is not enough successfull. Looks it need more tutorial about scripting. Anyway thanks for your help.(Your link is I already covered but thank you once again for sharing). Have a nice scripting ![]() ---------------------------------------- ![]() |
Current timezone is GMT Sep 26, 2026, 6:53:51 AM |
