Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Problem of executing the source code on eclipse |
| Print at Sep 24, 2026, 9:49:19 PM |
| Posted by Puybaret at Aug 11, 2014, 4:33:11 PM |
Re: Problem of executing the source code on eclipse at ... What about running a main class with a name that looks like Sweet Home 3D, maybe… com.eteks.sweethome3d.SweetHome3Dat org.freehep.util.io.ASCII85InputStream.main (ASCII85InputStream.java:147 ) Thanks, I have corrected that and now seeing this: Usage: ASCII85InputStream filename ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by banna at Feb 15, 2017, 1:18:57 AM |
Re: Problem of executing the source code on eclipse Hi Choppyleo! I am also getting the same problem. How to solve? Can you please guide me? |
| Posted by Puybaret at Feb 16, 2017, 8:41:18 AM |
Re: Problem of executing the source code on eclipse As already suggested, run the com.eteks.sweethome3d.SweetHome3D main class. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Dhel at Feb 18, 2017, 4:44:18 PM |
Re: Problem of executing the source code on eclipse Same concern, how can i embed and make an applet of sweet home 3d? thank you! |
| Posted by Puybaret at Feb 18, 2017, 9:50:43 PM |
Re: Problem of executing the source code on eclipse Dhel, applets are almost dead. You shouldn't invest time on this deprecated technology. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 9:49:19 PM |
