Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Import Furniture |
| Print at Sep 27, 2026, 8:50:28 AM |
| Posted by peterweaver at Feb 25, 2018, 5:25:46 PM |
Import Furniture Hi there, I am trying to import a furniture. After import a sizes are displayed differently than original sizes. Even when I type in sweethome: width,depth,height etc-an object is still different. Any ideas, what should I do? Cheers |
| Posted by Puybaret at Feb 25, 2018, 8:36:59 PM |
Re: Import Furniture What do you mean by original size? In which format is your imported model? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by peterweaver at Feb 25, 2018, 9:07:20 PM |
Re: Import Furniture The model has been imported in .obj format. When I put it into Import Furniture and original size is 600mmx600mmx880mm, then Furniture Import Wizard depth width height are totally different.When I retype it, then model becomes different. On the plan it shows a bigger rectangle and the model (inside of the rectangle) very small etc. |
| Posted by Puybaret at Feb 25, 2018, 9:25:41 PM |
Re: Import Furniture How did you obtain this OBJ file? Would it be possible that you share it? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by peterweaver at Feb 26, 2018, 2:38:06 PM |
Re: Import Furniture Hi Emmanuel, I have just sent you an email with an attachment of the .obj file. Cheers |
| Posted by Puybaret at Feb 26, 2018, 2:48:13 PM |
Re: Import Furniture You included in your model a small additional part far away from the main object. Removing it should help you obtain a correct model. You could have guessed it because the 3D model isn't centered when you import it in Sweet Home 3D furniture import wizard. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by peterweaver at Feb 26, 2018, 4:22:09 PM |
Re: Import Furniture Thanks a lot for your help. |
| Posted by peterweaver at Feb 26, 2018, 7:06:09 PM |
Re: Import Furniture Hi Emmanuel, Another thing, which I can not sort out in Sweethome. The object's front door has got a different colour and after Import Furniture there is still a grey colour, but it should be coloured.What Am I doing wrong during importing furniture in Sweethome? I have sent you an object via email. Thanks a lot for your help. |
| Posted by Puybaret at Feb 27, 2018, 10:17:09 AM |
Re: Import Furniture Colours are exported in the separated MTL file. When you import an OBJ file, you should generally keep the MTL file in the same folder (or the same ZIP file). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by peterweaver at Mar 6, 2018, 7:33:25 PM |
Re: Import Furniture Emmanuel, I am trying to create a photo and sometimes it is starting dark/grey. I am showing a floor/ceiling and 3 lights above the table. What Am I doing wrong? Cheers |
Current timezone is GMT Sep 27, 2026, 8:50:28 AM |
