Print at Sep 27, 2026, 7:32:17 AM
Posts: 18   Pages: 2   [ Previous Page | 1 2 ]
Posted by peterweaver at Mar 6, 2018, 8:09:02 PM
Re: Import Furniture
I have just figured it out.
Cheers
Posted by CIANFRES at Apr 2, 2018, 8:35:40 PM
Hi, I've downloaded a model .obj but i can't import it in my sweet home 3d. I've a Mac, maybe is it a problem?
I've downloaded it from a web site and in every folder there is the object and other files.
How can I import correctly the object?
Thank you
Francesca from Italy
Posted by Puybaret at Apr 2, 2018, 11:23:16 PM
If you use the Mac App Store version, you should import 3D models in zip archives.
For more information, please read the FAQ How can I import 3D models in OBJ, DAE or 3DS format with the Mac App Store version of Sweet Home 3D?
Posted by Steveworld7 at Dec 21, 2021, 2:11:44 PM
Colours are exported in the separated MTL file. When you import an OBJ file, you should generally keep the MTL file in the same folder (or the same ZIP file).
Hi! I have a ZIP file with a list of files inside as: 3ds, dae, obj, mtl and texture folders)
Importing this ZIP, the pouf inside remains white. Any suggest?
Thanks
Posted by Puybaret at Dec 21, 2021, 5:29:05 PM
DAE and 3DS files contain colors, at the opposite of OBJ files which colors are described in their accompanying MTL file (and sometime not well described). I would extract the DAE file ans try to import it.
Posted by Steveworld7 at Dec 27, 2021, 12:31:44 PM
I tried to import the .dae file only (after zipping it) but the pouf remains white ...
Inside this zip file there are 3 folders called: LODs, render, textures ... should I have to import these folders somehow?
Posted by Jo_Alfemo at Dec 27, 2021, 5:18:40 PM
Hi
If I want to make a texture what is the ideal size?
Tks
Posted by dape at Mar 18, 2022, 11:05:39 AM
Hi Peter, do not know if this can help, but if you are looking for more free 3D furniture models (and many more download formats), try here with 3DfindIT.com (have to register and then you can download for free whatever you need). Hope it helps, take care!
https://www.3dfindit.com/textsearch?lang=en_US&q=furniture
