Print at Oct 12, 2026, 7:53:10 AM
Posts: 31   Pages: 4   [ Previous Page | 1 2 3 4 | Next Page ]
Posted by hal9000 at Oct 21, 2018, 6:08:13 PM
Re: massive color-difference
Easy and simple idea - and it totally works!!!
For me this is a workaround and I can live with this as a solution, but I'm still wondering what's the issue with the colour...
Glad to know. I'm wondering it too. May be Emmanuel can explain it, although I'm not sure whether it's a SH3D or SunFlow issue.
If a long walk every day were healthy, mailmen would be immortal. tongue
Posted by Puybaret at Oct 21, 2018, 6:23:19 PM
Nobody complained until now but it's clearly an issue that should be fixed if possible, particularly if the rendering is different with a similar texture.
Please, open a bug ticket.
Posted by UbuntuBirdy at Oct 21, 2018, 6:40:06 PM
...done.
Posted by Puybaret at Oct 21, 2018, 10:06:58 PM
Thanks. I will investigate...
Posted by Ceciliabr at Oct 26, 2018, 5:48:16 PM
There's really no issue:
The reflected colours change as the light changes – just as in real life.
To best manage colours, the first thing you should do is to calibrate the brightness of your 3d view,
if you haven't done that already:
Apply a completely white texture to the sky.
Render different coloured objects with enhance external brightness checked, and no sunlight.
Adjust the brightness of the 3D view until the brightness is as close to the rendered image as possible.
_______
I find that applying a white top to a partly clouded sky image, is a good way to get nice daylight colours when using the enhanced brightness option.
cec
Posted by UbuntuBirdy at Oct 26, 2018, 7:35:29 PM
Sorry cec, but this IS an issue! Such massive differences are NOT like in real life.
Of course I have tried to adjust all the params, but none of them has improved the condition.
And why are texture colours not the same as only colours?
Posted by UbuntuBirdy at Oct 26, 2018, 8:42:33 PM
This picture shows what's wrong in my opinion:
- The left cube has a texture which is only colored as #520015
- The right cube has the color #520015 directly
In my opinion both cubes should look the same, we should see exactly the same color. But only the textured cube shows the color #520015 as it should be.
Posted by Ceciliabr at Oct 26, 2018, 10:02:27 PM
You are absolutely right!
I totally misunderstood the problem.
Here is a test with white, showing the opposite effect between the preview and the rendered image.
cec
Posted by UbuntuBirdy at Oct 26, 2018, 10:33:11 PM
I think it makes sense to post the link to the bug ticket.
This way anyone can add further informations regarding the problem.
Posted by Superpippo at Nov 16, 2018, 3:12:34 PM
Problema simile ... Cielo costantemente rosso anche se cambio colori o Texture se faccio foto in modalità 3 o 4 ... parzialmente risolto : 1) mettere in modalità visita virtuale 2) alzare la testa dell'omino e inquadrare solo il cielo 3) fare una foto in modalità 3 o 4 e vedere se il colore si è resettato e il cielo è tornato blu 4) abbassare gradualmente la testa continuando a verificare che tutto sia tornato a posto 5) vedere con l'inquadratura giusta gli sfondi sono tornati normali 6) fare la stessa verica con l'inquadratura 3d aerea 7) cambiare i punti cardinali o inserire una luce bianca se alcune Texture danno sul giallo
