Windows 11 - not possible to save/save-as !!!!!
This topic has been viewed 6801 times and has 10 replies
I installed 7.2 it would't save or save as any new project,Java was smoothly. And i try lot of steps the same of http://www.sweethome3d.com/support/foru ... read,11932 but finall would't save or save as....
Re: Windows 11 - not possible to save/save-as !!!!!
What do you mean by it "wouldn’t save"?
It not able save or save as when i want to have a new project it nothing happened as "I try to open a file ("open" dialogue) nothing happens. Same when I try to save or save-as, nothing happens. When I try to close the application it asks me if I wanted to safe the progress - when I click save nothing happens, no window pops up for me to choose the destination....." from anothers case of forum.
Thanks for your support & helf...better to have any ID of online chat then easy to show what appened now.
Maybe try to run the program as administrator.
Even if it’s not the best solution, you could also start from an empty file that you would open with a double click then just choose the Save menu item. Just use the EmptyFile.sh3d attached to this post and rename it if you want.
- EmptyFile.sh3d
- (3.2 KiB) Downloaded 1385 times
Yes,I do and able to save but wouldn't save as...what's happening...please help to solve it. Need to change Windows version or not?
I try to run with administrator but the same...wouldn't save or save as.
Run the program from a terminal window
Only logs might help me understand what’s going on.
I have do it but nothing happened and did't get log.
Any other options to solve this problem?
See bug #1212
