Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Side view plug-in |
| Print at Sep 23, 2026, 12:34:36 PM |
| Posted by ContrActorLA at Mar 20, 2024, 10:51:58 PM |
Re: Side view plug-in Hello! I've downloaded all the plug-ins except the Furniture Library Editor. My Mac will not let me open it because it is from an "unidentified developer". Do I need this to be able to see and edit my dimensions in 3D? I can add a couple dimensions, but cannot move or edit them in any way. And when I use the Side View tool, the dimensions do not show up. I've tried to follow all these threads closely and do as they instruct. Also, I am unable to save the Side View image to my hard drive. I would only be able to create a screenshot of the view window. What am I missing? Does it come down to the furniture plug-in? Thank you for your advice. |
| Posted by Keet at Mar 21, 2024, 9:33:09 AM |
Re: Side view plug-in The Furniture Library Editor is not a plugin but a separate application. The Texture Library Editor is also a separate application. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by ContrActorLA at Mar 21, 2024, 10:44:37 PM |
Re: Side view plug-in So the Furniture Library Editor has nothing to do with why my dimensions are not working in 3D nor showing up in side view? I'm curious with what is missing that these functions are not working. |
| Posted by Puybaret at Mar 21, 2024, 11:31:51 PM |
Re: Side view plug-in Do you use the last version of Sweet Home 3D? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ContrActorLA at Mar 22, 2024, 12:40:41 AM |
Re: Side view plug-in Yes, sir. 7.2.1 from the Mac App store. |
| Posted by Puybaret at Mar 22, 2024, 1:37:05 AM |
Re: Side view plug-in Then be sure to use the last version of the plug-in too and read this article. With the Mac App Store version, the image can be saved only in the folder proposed when you click on Save button (or a subfolder), because of security reasons forced by Apple. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Tapi35 at Sep 5, 2024, 10:48:38 AM |
Re: Side view plug-in Hello, Thanks for this great project, but it doesn't work in my case. I have a project with several levels, when I launch the side view, the preview remains white even if I change point of view or level. Do you have any idea of the problem? I'm using sweet home 7.5 and sideview 1.1. Thanks in advance |
| Posted by NIMAN at Jan 16, 2025, 12:43:56 PM |
Re: Side view plug-in I finished drawing my renovation/extension in SH3D last July with the idea to outline a set of SH3D plan / side view elevations jpg images in Inkscape for planning & building control applications when the chance arose. The chance arose today. SH3D is Version 7.2 and this is a Win 7 Pro 64bit 4GB RAM. The plugin manager reports Side view 1.1.1 as installed. I'm definitely rusty with SH3D after the lay off but can't see the side view plugin in the tools menu after (several) restart. Any advice appreciated. https://i.postimg.cc/dQX8zq8W/SH3-D-SIDE-VIEW-EXTENSION-MISSING.png |
| Posted by NIMAN at Jan 17, 2025, 10:32:35 AM |
Re: Side view plug-in Having installed the side view plugin from the homepage the issue is now resolved. |
| Posted by FredGold at Sep 1, 2025, 10:07:39 AM |
Re: Side view plug-in Hi, this looks interesting. Would that plug-in allows to get a profile view in a kitchen or bathroom ? Thank you |
Current timezone is GMT Sep 23, 2026, 12:34:36 PM |
