Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released |
| Print at Aug 9, 2026, 12:27:20 PM |
| Posted by enkonyito at Aug 12, 2021, 4:29:29 AM |
Re: Furniture Library Editor released @Puybaret For interested programmers, source code is committed in the FurnitureLibraryEditor SVN module separated from SweetHome3D one. Furniture Library Editor project is derived from Sweet Home 3D project and uses a similar MVC architecture. Project contains a README.TXT file with compilation directions. Is there a javadoc to view online or download? ---------------------------------------- EnkoNyito |
| Posted by Puybaret at Aug 13, 2021, 2:37:27 PM |
Re: Furniture Library Editor released No but you could generate the javadoc if needed. Just look at the javadoc target in Sweet Home 3D project to see how. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kotbasikcom at Aug 14, 2021, 11:05:28 AM |
Re: Furniture Library Editor released Good afternoon. Please tell me how to add a choice of language in the program settings. I translated the .properties files, inserted them into the program, but in the choice of language, all the same, only English and French. Thanks. |
| Posted by Puybaret at Aug 14, 2021, 5:04:30 PM |
Re: Furniture Library Editor released The list of languages supported by the editor is returned by the getSupportedLanguages method in FurnitureLibraryUserPreferences class. Just add the language code you want to the array returned by this method. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kotbasikcom at Aug 14, 2021, 9:27:51 PM |
Re: Furniture Library Editor released Thank you very much |
| Posted by enkonyito at Aug 17, 2021, 4:36:26 AM |
Re: Furniture Library Editor released No but you could generate the javadoc if needed. Just look at the javadoc target in Sweet Home 3D project to see how. After adding the "javadoc" target in the build.xml file of the FurnitureLibraryEditor project, "<!-- addition start (EnkoNyito) -->I get this message in the console: Buildfile: C:\Users\user\eclipse-workspace 4.16 (2020-06)\FurnitureLibraryEditor-1.28_derived\build.xmlbut the FurnitureLibraryEditor-1.28-javadoc folder is empty. ---------------------------------------- EnkoNyito |
| Posted by Puybaret at Aug 17, 2021, 9:36:58 AM |
Re: Furniture Library Editor released I just tried your target on my side and it worked with JDK 1.8. There were some errors because the classpath wasn't complete but FurnitureLibraryEditor-1.28-javadoc.zip was generated and usable. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Aug 28, 2021, 5:00:55 AM |
Re: Furniture Library Editor released By modifying the source code, I was able to add 2 new properties (LIGHT and LIGHT_SOURCES). This adds a 'Light' column and a 'Light sources' button. FurnitureLibraryEditor-1.28_derived.jpg For certain color (#44371B), this one is not taken into account in the PluginFurnitureCatalog.properties file and the console returns the message java.lang.NumberFormatException: For input string: "FF44371B"---------------------------------------- EnkoNyito |
| Posted by enkonyito at Aug 29, 2021, 11:34:09 PM |
Re: Furniture Library Editor released By applying a mask (0x00FFFFFF), the 'Color' button returns the correct int value that is taken into account by the FurnitureLibraryFileRecorder class for writing the LIGHT_SOURCE_COLOR property. ---------------------------------------- EnkoNyito |
| Posted by harbinger at Aug 30, 2021, 11:42:34 AM |
Re: Furniture Library Editor released Can you link to the version history of the FLE? I'm not finding what's new with the latest version? |
Current timezone is GMT Aug 9, 2026, 12:27:20 PM |
