Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released |
| Print at Aug 9, 2026, 1:35:19 PM |
| Posted by Puybaret at Aug 31, 2021, 2:27:26 PM |
Re: Furniture Library Editor released There's no separated version history for the Furniture Library Editor. The version 1.28 only brought some icon changes. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Sep 2, 2021, 3:12:02 AM |
Re: Furniture Library Editor released For building the FurnitureLibraryEditor-version.jar file with the furnitureLibraryEditorJarExecutable target, the Color button does not open any panel and displays this message in the command prompt: Exception in thread "AWT-EventQueue-0" java.lang.IllegalArgumentException: input == null!In Eclipse, the Color button opens the color modification panel. ---------------------------------------- EnkoNyito |
| Posted by Puybaret at Sep 4, 2021, 9:32:35 AM |
Re: Furniture Library Editor released Many files of Sweet Home 3D are excluded from the JAR executable file of the Furniture Library Editor, to build a JAR file as small as possible. If you change the features of the editor, you'll have to check which files you should not exclude anymore. In your case, I guess you need the pipette cursor icons found in com/eteks/sweethome3d/swing/resources/cursors folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Sep 5, 2021, 10:17:55 PM |
Re: Furniture Library Editor released Indeed, the problem is solved by including the pipette cursor icons. Here is the derived version that allows to create lights and modify their sources. FurnitureLibraryEditor-1.28_derived.jar FurnitureLibraryEditor-1.28-src_derived.zip Note: As it is not possible to attach the files because apparently their sizes exceed the maximum allowed, I put links to SourceForge. ---------------------------------------- EnkoNyito |
| Posted by harbinger at Sep 20, 2021, 2:39:17 PM |
Re: Furniture Library Editor released The derived version works well, but i'm leery of those icons. Yuk! Would be great if the light editor would draw where the light source is in relation to the model, using the XYZ we enter. I love the fact that i can adjust the color right there! |
| Posted by enkonyito at Sep 20, 2021, 5:35:06 PM |
Re: Furniture Library Editor released @harbinger The derived version works well, but i'm leery of those icons. Yuk! The standard version of the FurnitureLibraryEditor-1.28 tool uses the new icons of Sweet Home 3D 6.6 .Would be great if the light editor would draw where the light source is in relation to the model, using the XYZ we enter. I love the fact that i can adjust the color right there! It would be interesting but this problem does not yet have a solution.---------------------------------------- EnkoNyito |
| Posted by davidzhghenti at Oct 23, 2021, 8:10:02 PM |
Re: Furniture Library Editor released Good day all.. I download this program... In YouTube I saw Up panel is "Tools". near the File, EDIT, Plan, Help. in this How I add "TOOL"? thanks,,, |
| Posted by Puybaret at Oct 23, 2021, 10:16:45 PM |
Re: Furniture Library Editor released I don’t know what you saw but the Furniture Library Editor is a separated application as explained in the first message of this thread. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by enkonyito at Oct 27, 2021, 11:11:01 PM |
Re: Furniture Library Editor released FurnitureLibraryEditor-1.28.1_derived
executable jar source code ---------------------------------------- EnkoNyito |
| Posted by Andrew_Somovo at Dec 1, 2021, 5:57:43 AM |
Re: Furniture Library Editor released Hello! I would really like it to be possible to edit and save the price in the FurnitureLibraryEditor, so that when importing in the library, the price is linked to the model! Is there a way to do this? Our company is ready to pay for it, how much will it cost? |
Current timezone is GMT Aug 9, 2026, 1:35:19 PM |
