Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released |
| Print at Aug 9, 2026, 1:35:23 PM |
| Posted by Puybaret at Dec 1, 2021, 10:24:56 AM |
Re: Furniture Library Editor released Hello Andrew, You'll find a version with the additional Price / VAT / Resizable / Texturable fields in I also added Resizable and Texturable check boxes which prevents from resizing an object and changing its color / texture in Sweet Home 3D, when unchecked. If you want to preset the price of an object, I guess it's for real products which can't be resized or colored, right? I would be happy to know your actual use case. The management of these fields was already programmed but disabled in the default version. If you like it, I'll add a Price option in the preferences of a future version of the Furniture Library Editor to enable them and avoid keeping this special version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Andrew_Somovo at Dec 1, 2021, 11:16:47 AM |
Re: Furniture Library Editor released Emmanuel, that's Great! Thank you very much, I will test it now! |
| Posted by Andrew_Somovo at Dec 1, 2021, 12:00:38 PM |
Re: Furniture Library Editor released Emmanuel, everything works, you are God! How much money does it cost, where to transfer it? |
| Posted by Puybaret at Dec 1, 2021, 1:18:56 PM |
Re: Furniture Library Editor released It's great that you like it ![]() You can make a donation if you want. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Gigi0ne at Apr 6, 2022, 7:01:43 PM |
Re: Furniture Library Editor released hi i have a small problem .. any idea? thank's [luigi@localhost burla]$ java -jar FurnitureLibraryEditor-1.28.jar Exception in thread "main" java.lang.reflect.InvocationTargetException at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) at java.base/java.lang.reflect.Method.invoke(Method.java:566) at com.eteks.furniturelibraryeditor.FurnitureLibraryEditorBootstrap.main(Unknown Source) Caused by: java.lang.UnsatisfiedLinkError: Can't load library: /usr/lib/jvm/java-11-openjdk-11.0.14.1.1-5.fc35.x86_64/lib/libawt_xawt.so at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2630) at java.base/java.lang.Runtime.load0(Runtime.java:768) at java.base/java.lang.System.load(System.java:1837) at java.base/java.lang.ClassLoader$NativeLibrary.load0(Native Method) at java.base/java.lang.ClassLoader$NativeLibrary.load(ClassLoader.java:2442) at java.base/java.lang.ClassLoader$NativeLibrary.loadLibrary(ClassLoader.java:2498) at java.base/java.lang.ClassLoader.loadLibrary0(ClassLoader.java:2694) at java.base/java.lang.ClassLoader.loadLibrary(ClassLoader.java:2648) at java.base/java.lang.Runtime.loadLibrary0(Runtime.java:830) at java.base/java.lang.System.loadLibrary(System.java:1873) at java.desktop/java.awt.Toolkit$3.run(Toolkit.java:1399) at java.desktop/java.awt.Toolkit$3.run(Toolkit.java:1397) at java.base/java.security.AccessController.doPrivileged(Native Method) at java.desktop/java.awt.Toolkit.loadLibraries(Toolkit.java:1396) at java.desktop/java.awt.Toolkit.<clinit>(Toolkit.java:1429) at java.desktop/javax.swing.UIManager.getSystemLookAndFeelClassName(UIManager.java:661) at com.eteks.furniturelibraryeditor.FurnitureLibraryEditor.initLookAndFeel(Unknown Source) at com.eteks.furniturelibraryeditor.FurnitureLibraryEditor.init(Unknown Source) at com.eteks.furniture |
| Posted by Puybaret at Apr 6, 2022, 7:07:07 PM |
Re: Furniture Library Editor released I think you should reinstall Java or reuse the java command found in the runtime/bin subfolder of SweetHome3D installation folder. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at Sep 18, 2022, 3:50:12 PM |
Re: Furniture Library Editor released Bug concerning imported object names. When importing multiple obejcts from a series with multi-select the names are not imported as they should. If have several objects named fence01.obj, fence02.obj, etc. When I select multiple of these they are all imported with the same name 'fence0'. Thinking removing the '0' would solve this I was disappointed that it resulted in multiple objects named 'fence'. So I tried to import them one-by-one. This made no difference and the names are still abbreviated when imported. Switching the preference setting for the model name also doesn't make any difference. So I investigated further. Opening the zipped library showed that all objects did have the correct name and each had an icon named accordingly. Importing the Library in Sweethome3D also showed the correct names in the furniture list. Conclusion: it's only the display in the Furniture Library Editor listview that shows a shortend name. I didn't test any other names but it looks like the last character is always lost. Furniture Library Editor version 1.28 Java version 1.7.0_261 System Debian Linux ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Keet at Sep 18, 2022, 3:58:05 PM |
Re: Furniture Library Editor released I just noticed the latest version 1.30 and installed that but the same name problem is still occurring. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Puybaret at Sep 18, 2022, 4:38:03 PM |
Re: Furniture Library Editor released It’s not not a bug. The trailing digit is removed on purpose when the Editor tries to compute a more readable name of the imported model. Maybe, it should be an option in preferences. Meanwhile add another character to your file name if you want to keep the last digit. Note also that hyphens and underscores in the model file name are replaced by spaces. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Keet at Sep 18, 2022, 5:15:13 PM |
Re: Furniture Library Editor released That explains why importing "Staircase 400 U.obj", "Staircase 400 L.obj", and "Staircase 400 Z.obj" do keep the correct name. The hyphen has another problem: replacing with a space is not a problem in itself although I would prefer that it was retained. When investigating I also tried "fence-1.obj", "fence-2.obj", etc. but ofcourse that also resulted in multiple objects named "fence". Adding an extra character after the number would be illogical in the case of a numbered series of objects. A preference to retain the full object (file)name would be very welcome. Some objects are in series by number and retaining the name when importing avoids the hassle to properly name them when you suddenly find yourself with multiple different objects with the same name in your list. If you get to implementing this preference please also add a preference a different default directory for libraries. After every restart of the editor I have to click through a long path to get to my directory with furniture libraries. Starting every time in the users home directory is fine as long as no other path is set but extremely frustating if you have a different drive and directory for your libraries. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Aug 9, 2026, 1:35:23 PM |
