Print at Sep 23, 2026, 11:53:16 AM
Posts: 226   Pages: 23   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Posted by enkonyito at Sep 11, 2017, 7:02:17 PM
Re: Photo-video rendering plug-in
Version 1.3
Compatible only with SweetHome3D-5.5 and higher
(lights rotation around a horizontal axis)
For video rendering:
- curved line for camera path (circular arc)
- variable speed according to distance
SH3D camera animation
EnkoNyito
Posted by enkonyito at Sep 14, 2017, 3:35:30 AM
The plug-in supports English and French but it is possible to add other languages based on the ApplicationPlugin_en.properties template.
Based on these instructions , the addition of a language can be done as follows:
1-unzip the PhotoVideoRendering-VERSION.zip file
2-transform the .sh3p into .zip
3-paste your file ApplicationPlugin_LANGUAGE.properties
4-transform the .zip into .sh3p
For any additional language integration directly to the plug-in for future versions, you can contact me .
Attachment ApplicationPlugin_en.properties (4768 bytes) (Download count: 1189) (Translation template)
EnkoNyito
Posted by enkonyito at Nov 4, 2017, 3:31:28 PM
Note to translators.
You can translate the label of parameters (rendering properties) by putting your translation in parentheses and separated from the English keyword by a space.
Example:
RenderingPropertiesView.aAminLabel=antiAliasing.min (\u6700 \u5C0F \u9297 \u92F8 \u9F52):
This structure must be respected otherwise the modifications of the parameters will not be taken into account for your translated file.
EnkoNyito
Posted by sclee at Nov 5, 2017, 10:16:17 AM
Thank very much for the help of Enko Nyito, so that the renderer has more choice, I also translated the traditional Chinese and Simplified Chinese,
download: http://sync.hamicloud.net/_oops/scleea/seh
Posted by Geovani141 at Nov 16, 2017, 2:19:33 PM
http://i66.tinypic.com/jruq0l.jpg[/IMG[/img]
Sorry, for my English. I have a problem.
I have version 5.6 of the software and I can not create a photo. I click on create photo and it loads but an error appears on the screen, a small icon with an 'x' in the middle. Before I could create photos normally, but now I have this problem. I even formatted my computer to see if it was memory, but it is not. Please help m e.
Posted by bdfd at Nov 19, 2017, 5:30:07 AM
[moderated]
Posted by Puybaret at Nov 20, 2017, 12:57:31 PM
Geovani141, this error might happen when the program doesn't have enough RAM to work. Read the FAQ to increase the maximum RAM that Sweet Home 3D can use.
Posted by enkonyito at Jan 5, 2018, 6:15:09 PM
Some details about the video rendering.
The curved line path is created automatically when there is a difference in orientation between 2 recorded positions.
The greater the distance between 2 recorded positions, the faster the movement speed.
Conversely, the shorter the distance, the slower the speed.
Practical tip to see the difference between a straight line path and a curved line path.
You can save your path in the standard video panel and then open the video plugin.
Since the positions recorded are the same, some parts of the path may be curved and the speed different depending on the distance.
At the next version! wink
EnkoNyito
Posted by enkonyito at Jan 30, 2018, 1:02:52 AM
Version 1.4
  • display a message about plug-in compatibility
  • display a message when closing a rendering
  • added a minimum night brightness (dark level 2)
  • selection, in the simple photo rendering panel, of available LookAndFeels
  • other minor bugs fixes and enhancements
(translation template)
EnkoNyito
Posted by enkonyito at Feb 16, 2018, 2:52:04 AM
@Ceciliabr
Just a question: Is it possible to make the image-window wider, f.i. 600px wide? That would be really useful.
Here's how the image display is processed in the default photo panel.
this.photoComponent = new ScaledImageComponent();
this.photoComponent.setPreferredSize(new Dimension(getToolkit().getScreenSize().width <= 1024 ? 320 : 400, 400));
To add additional options, I decreased the size of the image preview and since version 1.4 the size of the panel changes depending on the look and feel chosen.
But to answer your question, yes it is possible to increase the size of the image preview.
EnkoNyito
