Print at Sep 30, 2026, 11:39:26 AM
Posts: 98   Pages: 10   [ Previous Page | 1 2 3 4 5 6 7 8 9 10 | Next Page ]
Posted by Puybaret at Aug 4, 2017, 4:06:11 PM
Re: Sweet Home 3D 5.5
The version 5.5 beta 10 (Java Web Start, Windows installer and Linux 64 installer) comes with an update of Hungarian translation and a new look for the Furniture modification dialog box with different labels for the rotation around the horizontal axes.
Hope you'll find it clearer smile
I propose also a second installer for Windows with the version 5.5 beta 11, to get your feedback about how Sweet Home 3D works with the latest Java Runtime Environment 1.8.0_144, one year later I decided to stuck on JRE 1.8.0_51 to fix the crash problems encountered by some of you (the installer of Sweet Home 3D version 5.5 beta 10 still comes JRE 1.8.0_51). To check if it works better, I hope some of you will have the patience to test whether Sweet Home 3D 5.2 still crashes, then try the new version 5.5 beta 11.
Thanks for your tests smile
If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b
Posted by hansmex at Aug 4, 2017, 4:42:53 PM
The Linux_64_installer links downloads a file called SweetHome3D-5.5.beta11-jre1.8.0_144-windows.exe.
Is that correct?
Posted by Puybaret at Aug 4, 2017, 5:28:28 PM
Sorry Hans, I fixed the link. Thanks for reporting the issue smile
Posted by bdfd at Aug 4, 2017, 6:38:33 PM
...If needed, the MD5 of SweetHome3D-5.5.beta10-linux-x64.tgz is da2f87dfd603909f9f3d38973ce6051b
Not chance !
It's now the second link for linux which is bad... biggrin
Posted by Puybaret at Aug 4, 2017, 7:18:26 PM
Fixed. Thank you. Bad luck wink
Posted by okh at Aug 7, 2017, 1:56:29 PM
Guess 'nothing to report' can also be a report smile Worked my way through the features and did some random editing, and Java Web Start seems to work beautifully under Win81. Thanks for the new features. ok
Posted by bdfd at Aug 8, 2017, 9:48:52 AM
Just a remark : Today, I use sh3d 5.5 beta11 in exe mode with success.
I won in using jlnp method with a good '.bat' file. biggrin
but i saw that the launched version was beta12 !
Is it the good ?
Posted by enkonyito at Aug 11, 2017, 8:14:02 PM
Is it possible for the camera to tilt along the Y axis like furniture?
EnkoNyito
Posted by Puybaret at Aug 11, 2017, 10:00:15 PM
Bdfd, I don't post a message at each update, moreover when it's about very small changes, but you're right, the current beta version is 12.
Enkonyito, I wonder what your request could be useful for.
Posted by enkonyito at Aug 15, 2017, 2:37:35 AM
Emmanuel, this "roll" option may not be very useful applied to the virtual visitor but in the case of a video rendering this would be an additional basic camera movement.
EnkoNyito
