Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 5.5 |
| Print at Sep 30, 2026, 8:22:45 PM |
| Posted by bdfd at Sep 1, 2017, 5:30:00 AM |
Re: Sweet Home 3D 5.5![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by qythyx at Sep 2, 2017, 1:14:45 PM |
Re: Sweet Home 3D 5.5 I just tried to render a video with this version and it didn't work at level 1 & 2, basically nothing happens. When I try level 3 or 4 it works fine. |
| Posted by bdfd at Sep 2, 2017, 2:31:59 PM |
Re: Sweet Home 3D 5.5 I just tried to render a video with this version and it didn't work at level 1 & 2, basically nothing happens. When I try level 3 or 4 it works fine. No problem for me in these levels. But you: OS ? RAM ?, CG ?, ... ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by qythyx at Sep 4, 2017, 1:17:16 PM |
Re: Sweet Home 3D 5.5 This isn't really related to the new version, but I thought I'd mention it here anyway. I have a MacBook Pro with the LG 5k monitor. When running SH3D on that monitor it is quite slow. It seems that's because of the very high resolution. Interestingly it's slow not just operations that involve the main layout screen, just bringing up normal dialog windows is slow to the point that I can see the dialog components being drawn in the window. If I reduce the size of the window, or adjust the resolution settings, then it does get better, but obviously I'd like to use the full resolution if possible. Again, this isn't new to the new version. On a side note, is there a jar-only build of the new version so I can run it with Java 8 on MacOS? Thanks, |
| Posted by bdfd at Sep 5, 2017, 7:57:00 AM |
Re: Sweet Home 3D 5.5 ... It seems that's because of the very high resolution... Hi,What is your "high resolution" ? What is the weight of your used file ? ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Sep 6, 2017, 5:02:26 PM |
Re: Sweet Home 3D 5.5 Sweet Home 3D 5.5 was released today (including a Jar executable version, but without the portable version yet). Thanks to you all for your feedback and help! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by okh at Sep 6, 2017, 6:50:56 PM |
Re: Sweet Home 3D 5.5 Congratulations on the new release! Lots of interesting improvements as usual. Thanks. ok |
| Posted by bdfd at Sep 6, 2017, 7:32:01 PM |
Re: Sweet Home 3D 5.5 At this time, 5.5 works fine ! ![]() ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by qythyx at Sep 7, 2017, 11:15:09 AM |
Re: Sweet Home 3D 5.5 The builtin display is 2880x1800 and the external monitor is 5120x2880. I usually show the floor plan on the external monitor and the 3D view on the builtin. The file is about 30MB. |
| Posted by Ceciliabr at Sep 7, 2017, 11:59:53 AM |
Re: Sweet Home 3D 5.5 There seems to be a problem with creating pictures and videos at the two lowest qualities. I have tried with OSX Sierra 10.12.6, and with Yosemite 10.10.5. cec |
Current timezone is GMT Sep 30, 2026, 8:22:45 PM |
